R5 Rotor puller
Started by rded, July 10, 2023, 12:44:19 PM
rded
Is an M8 fully threaded bolt used for pulling the R5 rotor?
I thought I was going to use the M!0x1.25 bolt that I used on the AT1.
its the m10 x 1.25. the main retaining  bolt for the points cam is a 7mm
rded
#2
I didn't see where it would screw in?
Was in kind of a hurry.
same hole as the rotor bolt, the rotor itself is threaded though. take the points cam off and out and use that hole.
rded
I was in such a hurry the other day, removing the points cam exposed it. Thanks :metal:
