1981 Yamaha RD350LC 4300mi CA plated $12K - CL - Santee, CA
Started by SoCal250, September 03, 2023, 01:27:10 AM
(not mine)
1981 Yamaha RD350LC - $12,000
https://sandiego.craigslist.org/esd/mpo/d/santee-1981-yamaha-rd350lc/7661787479.html
-full restoration (restomod) from frame up, minus a few bolts, a few small scratches on some of the plastics. It's a rider!
-powdercoated frame
-tapered steering bearings, swing arm needle bearings
-fresh professional paint and decals
-seat cover
-conti classic attack tires
-R1 blue spot caliper conversion with EBC pads, EBC rotors, stainless lines and Brembo master. New rear pads
-DID gold o ring chain and new sprockets, 520 conversion
-tarozzi rearsets
-Jim Lomas expansion chambers
-fluids all around
-ASV ball bearing clutch perch
-new cables all around
-refinished wheels
-aftermarket radiator
-stock airbox from Japan
-I completely rebuilt the engine from top to bottom end with all new seals and gaskets. I also repainted it. Carbs have been rebuilt and jetted. I installed a new welded crank, but the stock one is included too. The bores were in great shape at nominal bore but they were getting close to the max nominal bore size so i had them machined to 1st Os. I installed RZ350 TKRJ japan pistons. Has new intake manifolds with Boysen fiber reeds. Oil pump was also rebuilt
-running RZ350 air forks which have been rebuilt and have new tarozzi stanchions
-NHK steering stabilizer
-only thing it needs at the moment is a horn as I never installed one. But all the wiring is there
-probably a ton of other things I'm forgetting
