Stuck ring?
Started by paul1478, March 28, 2024, 10:45:51 AM
Quote from: m in sc on April 08, 2024, 10:13:58 AMso.. was it too lean, heated up and stuck the ring? what was the cause?
Hi Mark,
that is my assumption. I had 2 ripped intake manifolds I did not notice. It had to have been running very lean.
The bottom two rings were stuck so tight I never was able to get the loose. I tried with some picks Chuck had. I have been trying to be nice to it while it breaks in but it is much better that it was. New porting seems to make a difference also.
makes sense. UPP ones? i know chuck killed one a year + ago. this is also why i support the backs of my carbs w those.
Glad you got it sorted.  :olaf:
It was the original ones Chuck but on when he built it.
I changed them again when we went through it last week. I will change them every 2 years now and inspect them when cleaning the bike.
I always try and learn from my mistakes.
lowandslow
I am in GA too and new to this forum. Who is DR Quinzler ? Is he in GA too?
chucks in FLA and used to have a shop that did top notch work, life changed and now is not in the MC industry as a brick and mortar anymore. thats the simplest explanation. Look at bottom of forum, hes 'team scream' theres a (sub section in vendors).
