Modifying an R5 HL switch for use on the LC
Started by m in sc, May 28, 2024, 11:57:12 AM
So, i had a generic switch on the lc for headlight control. wasn't great as the switch was down, low beam, middle, off, up high beam. there was a definite delay from low to high and was kind of fiddly. didn't like it.  :huh:
. that being said, i used to run an r5 switch, and saved it. way back, i used the horn button hole to house a neutral light. i found that in the switch box, took it apart, and completely rewired it. cleaned contacts, hit it w matte clear, and added a 2-way momentary on switch with 'up' now working 'set' on the daytona gauge, and 'down' being mode. it centers automatically so, was perfect for this application and actually fit in the housing with a slight massage of the housing.
also needed to replace the 8" headlight bucket as the plastic housing cracked over time and needed to go. went (back) with one of the economy cycle/emgo headlights with an auxito led.
Extremely sanitary! Another job well done  :thumbs:
thanks wade!. the zip tie on the bar actually bothers me. (old man mode engaged)
I have an idea.....
scully
