'How To' JL pipe mod
Started by SUPERTUNE, November 16, 2019, 12:10:49 AM
Quote from: SUPERTUNE on February 24, 2020, 10:57:30 AM
Quote from: pdxjim on February 22, 2020, 06:03:46 PM
Why not just replace the studs with allen cap head bolts?
Jim,
All aircooled  RD350's and 400's have the top exhaust studs in the cylinders go into a open backside threaded hole and most don't come out from rust and corrosion. So the chances of the studs coming out and leaving good threads is really slim.
I have to drill them out 90% of the time.
If I do get them out...I'll use the new shorter studs.
C
Thx for that Chuck.  Been awhile since I messed with aircooled RD cyls.  Last few bikes I've done, TDR, KH400, and LC I've had more trouble keeping the studs in than getting them out.
Great work, I knew spacing was different from having to slot flanges sometimes but did not know was that much.
Quote from: Hawaii-Mike on February 22, 2020, 05:32:35 PM
The socket nuts were delivered today - two days after I ordered them..
Are you in Hawaii if so that's impressive.
Yes I'm in Honolulu and I was shocked!  Priority should only take 2-3 days however vendors seem to be allergic to mailing things here.
rd400greenhorn
This setup does not use an o ring?
Only the base gasket?
I did use a ring gasket on the base with Ultra gray gasket maker and no o-ring just glue into the spigot with the same Ultra gray gasket maker.
