To pod or not to pod? Suzuki GT200 carbs
Started by NoRiders, May 22, 2020, 10:43:28 AM
NoRiders
#30
Quote from: motodreams on May 25, 2020, 10:03:32 AM
Metal likely worse for reasons mentioned above!
RZ responds very well to filters as Mark said!
I would expect a slight increase in performance and gas consumption along with a lot of jetting work to get it right using pods!  Personally I use stock airbox unless I don't have one or trying to squeeze out a bit more power.  Pods look better and perform better plus are usually a lot cheaper than finding a stock airbox.  There must be an application out there that may be non-motorcycle you will have to source as I've seen pods on all sorts of motors...
Thank you. I'm having to order some small O rings on the throttle stop thingy....the supplier carries all types of jets etc, so thought to order a few to play with.....what increments would make sense?
Or, should I bite the bullet and order a Sigma jetting kit from the US?
Stock jet sizing:
Main - 82.5
Pilot - 20
Needle position - 4
I think raising or lowering the needle alters fuel intake, along with a rise in jet size would also enrichen the fuel....does this compensate for the pod filter? Plug colour will be the test...or a blown engine!! Haha.
NoRiders
Stripped the carbs and found the mains are 87.5,so does that mean they've been upgraded by 5.0?
In which case that might balance the pod filter with a richer position on the needle too, perhaps?
New to carb jetting etc. Any help appreciated.
One size prob wont do it, usually 3 or 4 will get close on a piston port. (assuming it sized in 2.5 incrememnts)  few more sizes for the chambers. you're just going to have to test.  this si from experiences with a GT250 and rd chambers. so, similar.
NoRiders
Quote from: m in sc on May 29, 2020, 06:07:49 PM
Ah, Ok thanx...never jetted up before so interested to hear your advice. Looks like I can get varying sizes, so a selection might work when it comes to it?
you'll probably need to rejet for the foam.
