"Shogun H1"
Started by 2 Stroke Jamoke, February 11, 2019, 03:16:43 AM
Sounds good Ian and looking forward to seeing it in a couple weeks.
Got to love John's reed engine setups!
Will be fun to ride...
2 Stroke Jamoke
 :metal: thanks guys, cant wait to see everyone at the dragon!
JA-Moo
She does sound sweet!  :righteous:
2 Stroke Jamoke
I put 30 or so miles on this thing and it flat out flys! Sure does vibrate alot, I need to make a better seat. There is a terrible sound that happens at about 6k. I took the heads off and can confidently say it is not detonating.  I think it might be my pipes vibrating against each other, there is about 1/4 inch between them but they are on rubber and can move a bit. Its tight down under there. I think I might try to wedge a piece of inner tube in there temporarily and see if it stops. Whoohoo it runs like a scalded dog! Also I think the tank paint turned out quite nice!
JA-Moo
There you go! Fun time!  :righteous: Triples vibrate a lot. A good vacuum sync, and slide sync helps a lot, but still.
2 Stroke Jamoke
During my ride yesterday I had more than one upshift that grabbed 2 gears. Example: 1st to 3rd, or 1st to like 2.5. My rearset shifter ratio is likely a little high compared to stock. I found a mod on the KTOG page and I'm proud to say I pulled it off! I welded on a little piece from another shift shaft (I think it was from my yamaha r3) that holds the drum in place until the shifter "resets" works excellent! It's like a modern bike shift shaft now! Pic below :metal:
JA-Moo
2 Stroke Jamoke
Heres a 2020 update on my h1 hybrid.  I'm going with the classic white and blue stripe paintwork. I think it turned out stellar! Also going back to the stock seat and rear bodywork. Heres some pics including one of my freshly "modified" center pipe lol
The white/blue looks great! :clap:  OUCH on that pipe!
What a cool bike! I dig the new paint.
Plus 1 on paint scheme, first time I've seen this thread great build I put Banshee engine in GS500 a couple of years ago.
Paint turned out great. the green was OK but this looks the part...
yeah, the body work looks wayyyyy better.  :clap:
2 Stroke Jamoke
Thanks guys, I never liked the way it looked, and the riding position was not ideal. I think the stock seat will really help. Heres one more pic with the panel and tail light on
