VT500 Honda Ascot...
Started by AAAltered, July 13, 2020, 10:31:39 PM
~JM~
Do you have the side covers? They are highly sought after.
A good fuel tank is worth quite a bit. They tend to rust through (ethanol fuel & water) at the lowest back corners.
That is one sad looking Ascot. Not sure that I'd believe the engine rebuild story.
this the rebuild kit he used?  :dawg:
It still can be modified towards a nice street tracker. 38-41 mm conventional forks and maybe a chain drive conversion? If the output shaft spins in the right direction.
