Aluminum swingarm quest
Started by 85RZwade, September 01, 2020, 09:18:07 AM
Thank you all for chiming in! This thread has produced some GREAT information  :patriot:
Between the members here couldn't we do a run of aluminum swing arms?
I could machine the dropouts, shock mounts, chain guard bung, and the butt joints on the tubing. Somebody will have to bend the tube, do the welding, and machine the front tube to fit bushings. A jig should also be made.
I'd a guess that a minimum run of like 5 or 6 would be required, but given that this thread continues to march on that should be doable?
Oh, my. This has just taken a tantalizing turn... I would be in for an RD350 arm for sure.
With fall just around the corner this is really the perfect time, IMO, to organize a project like this. If anybody is interested, either in purchasing an arm, helping fab, or both, send me a PM. Let's try to get it going.
and heat treating to be done correctly.
Why reinvent the wheel, like I said in another thread someone with the equipment and skills could do what ever needs to be done, added to the motolanna and sell them.
i agree. a motolana arm modded for an rd ready to bolt in would be very useful and prob way cheaper.
or
4130.
:whistle:
If I was going to design an arm for myself I'd use a thin wall 4130 that's slightly smaller in ID than the stock thick wall tube. I'd bend it, then flatten it slightly in the press so that the oval shapes thick section would be oriented laterally. This would make an arm that was both lighter and stiffer than the stock arm. For what though? There's no real reason to do it, so I've not done it. And I personally prefer the look of the round tube swing arm.
People seem to like that retro/monoshock look though.
As for heat treating, given the loads a twin shock arms sees, it simply isn't needed. Though I do agree it would be ideal.
should on the aluminum, just good practice. But as said, prob not needed.
Quote from: m in sc on September 06, 2020, 07:58:06 PM
or
4130.
:whistle:
Only problem is Motolana does not offer longer lengths
oxford
Quote from: rodneya on September 06, 2020, 09:19:05 PM
How long are you looking for?  Pretty sure they are +1 for a 400 and would be +2 for a 350.
Quote from: oxford on September 06, 2020, 10:37:41 PM
Motolana arm is for a SR500, not and RD. It is 1/4 inch longer than the RD350 arm according to the internets.
im pretty sure nathan told me his was a bit longer than that on his 350. .02
Dimensions for the Motolana that I found posted online a while back. No guarantee they are accurate.
length to mid adjustment 18.25"
Pivot spread 8.28"
axle spread 7.25"
oxford
Based on this picture I see 18.5" from pivot to axle.
I have a 400 arm on my bike and it measured around 16.5" from pivot to axle.
Nathan reported the moto lanna to be 1" longer than stock 400.
I have no real idea on what is what other than what the arm on my bike measures.
