10 mm shorter swing arm bolt for RD350A
Started by Dvsrd, September 21, 2020, 12:20:32 PM
Quote from: klaird on October 16, 2020, 06:39:46 PM
Is it possible to reverse the bolt and have long end on the left side?
yup.
suey1958
Probably will do as Mark suggested and just trim some off for a better look.
That bolt originally had two nuts on it from the factory. My stock 350 has two and also partzilla shows two.
Are having the 2 really necessary or will 1 be OK?  Thanks
Quote from: suey1958 on October 18, 2020, 07:55:06 PM
The second one is a lock nut.
you can use a 400 nut as i think it only is the one (thicker), or get one from mcmaster. they have nylocks that big. .02
suey1958
Thanks, I was aware that the second bolt was a lock nut but wasn't sure it was really needed. The nylock sounds like a better option. Thanks again
