The Millennium pipe future (aka Moto Carrera pipes)
Started by GRA2STROKES, March 15, 2019, 06:44:00 PM
GRA2STROKES
They will be a round silencer and will come in 2 lengths. I figure an option would be a great thing to to have.
Garrett
GRA2STROKES
Thanks Jim. I'm probably the most computer illiterate young person you'll ever meet. Anyway here's what I have been up to.
Garrett
Nice!
What kind of powerband is to be expected on a non-ported 350?  Power dropping off before any major mayhem occurs?
Quote from: GRA400c on April 28, 2019, 07:01:44 PM
Garrett
team work makes everyone happy!!
GRA2STROKES
Quote from: Dvsrd on April 29, 2019, 11:49:05 AM
Nice!
I ran these pipes on a stock ported 350 with cut heads and 30mmcarbs and had A solid 5500-9500 power band.
Garrett
GRA2STROKES
So I got my quote back and I was pretty blown away at cost. It was going to be $385 per set in machined parts. That's a total of 10 machined pieces per set of pipes. I have decided to use the burned flanges and a piece of 1-1/2 od tubing. The pieces welded on to the pipe will still be machined and seal with o rings. The tubing is surprisingly round and with work fine as well as be substantially cheaper. I believe it will still tied a high quality pipe at an affordable cost. Still shooting for 599-649 range.
Garrett
Looks good!
However, I do wonder if the machining cost would be lower if the o-ring grooves were on the spigot, and the piece welded to the pipe was just a piece of larger tubing, or a straight bushing?
Just seems easier to cut grooves on OD, rather than ID.
:twocents:
I really like that TZ style design with twin O rings but it's an expensive way to do things unless you are set up with a CNC lathe.
Single external O ring suggested by Dvsrd might reduce cost a bit.  Check out the Jim Lomas design for a simple version of single external O ring.
On my RD drag race pipe I was able to use some chopped down TZ "headers, but for production, costs need to be low.
GRA2STROKES
Actually the piece with the o ring grooves is not bad price wise even with a lower quantity of 20.
Yes I see how loomas does it but that sealing actually sucks. Owned a few sets and his flanges suck. I wanted to do better than that. I'll get some more picture up tomorrow for what I came up with.
Garrett
Tyga silencers are only $50 each retail.
They'd probably cut you a bulk/wholesale deal and sell em to you without the nameplate if you ask nice 🤷🏻‍♂️
