Mat Oxley 1986 IOM TT
alteration of intake port on RD350 cylinder
Started by Still biking, December 20, 2020, 04:57:48 PM
Still biking
Check the alterations on the intake port on these cylinders on Ebay.  Also, cut out above intake of cooling fins.  Any Ideas why this was done and if it improves performance?  see https://www.ebay.com/itm/333830105894?ViewItem=&item=333830105894
Seizer
Maybe they relief cut the fins to fit in a different frame?
bitzz
My guess would be it was modified to accept a balance tube intake like a RD400 or RZ.
The way the port is hogged out probably a RZ or Banshee intake.
Looks like he was running them with the tabs still on the piston skirts.
Quote from: bitzz on December 20, 2020, 08:38:27 PM
^ this.
ive seen them angled towards the cyl as well using straight intakes.
RdsOnly
nPERIOD CORRECT- POWER MODS
jtOT WORTH COMMENTING ON- SO WRONG FOR
racerclam
Just stupid grinding the reeds cover those trenches , all it did was increace crankcase volume
Rich
And that would generally be a good thing as long as the pipe can use the extra volume. Let the waves do the work...
