Whats in my garage
Started by busa1300, March 24, 2019, 06:11:25 PM
busa1300
#75
Thanks guys  :thumbs:
The addiction continues.....
I have a set of cylinders off to Tuning Works in the UK for a 300 big bore
A set of Veronesi intakes from Italy on their way, so I can mount some Lectron 38's onto my RGV VJ21SP that I had abandoned for 5 months.
I have a NOS crank in the box sitting on the bench and all my dry clutch rebuild parts ready to go in....
Might have it running by first snow.... :eek:
Also have a dyno appointment for the 17th to see what my A/F ratio is on my RZV, and also the TZR/SP
Nothing worthy of pics yet.
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
busa1300
Short dyno run at Valley Racing with the RZV500R
https://www.facebook.com/157353800971854/videos/311673996793205/
Bike was running lean from bottom all the way to the top according to the A/F ratio
But now I know what to do to get it better and start making some good HP runs
busa1300
#78
Thanks  :thumbs:
It sounds considerably more intense in real life closed up in the dyno room, than the vid portrays....but my phone is junk for videos  :bang:
A couple more pics of the dyno day.
The TZR/SP had a very good A/F reading throughout. But the factory restrictions really killed the powerband after 9000RPM
After the RZV is dialed in to my satisfaction, I will hook up the SUGO kit ignition, and get the powerjets operational on the 36 Mikunis....with my SPR air inlets for full power.
busa1300
Finishing up paint work, and collecting bits to get the engine back together for the VJ21/SP....but not much to show for all the time that has passed.
Test fitting Lectrons for cables
Veronesi intakes to adapt the 38mm Lectrons in a upright position
busa1300
The 300 big bore parts are here for the VJ21/SP
Almost time to get it all in one piece
Quote from: busa1300 on November 14, 2020, 08:24:53 PM
Looks like Christmas came early
busa1300
#83
Yes it came early  :thumbs:
Too bad I had to use my money for my own presents....but at least I got what I wanted....
Going through all the parts I have bought, trying to see what I have forgot for the RGV/SP
All new dry clutch plates, and the various oil seals that are needed, powervalve cables, throttle cables, clutch cable, oil lines...and my new crank are already here.
I have a new list started, but I'll get serious this weekend and try to make one last order.
busa1300
I can almost see the smoke rolling out.... ;D
Bike porn at it's purist.........................................D
busa1300
#86
Thanks   :thumbs:
Trying to get as close to a GP bike as I can for the street
Yamaha strokers in hibernation mode.....
busa1300
Still inching away on the RGV
Waiting on a set of shorter intakes for my carbs, and a set of shorty kit baffles from Japan yet.
Wiring done for the Zeel and my Dyna coils.
Powervalves set, TPS set, and ignition curves programmed in.
Kicked over and have spark.
Almost there.
busa1300
#88
It's first few minutes of it's new life
Sweet. Those lectrons look pretty good in there
