Can I use 1A1 Carburetors on RD350
Started by KANDY, April 11, 2021, 10:00:06 AM
KANDY
Hi All,
Did anyone used 1A1 carburetors from RD400 on 73-75 RD350.
Is it advisable, may I know what modification for using on stock RD350
1974 RD350
1981 RD350LC
1977 RD400
1980 RD400 Daytona Special
I bought a set of RD400 carbs that already had the Dave F mod done to use on my 350. All I did was remove the breather fittings from the bowl and clock them off.
They are basically the same carb as the 350, they just have the little hole near the top to sync your slides
KANDY
Thanks for the Reply.
I got a pair of good 1A1, Thought I can give to my friend whose RD350 Carb is not in good condition.
1974 RD350
1981 RD350LC
1977 RD400
Yamaha 179
You shouldn't block off the float bowl vents.  You should run a short - about 4" long piece of fuel line up towards the air box.  That vent is to equalize the air pressure between the float bowl and the atmosphere, IIRC, and is necessary for proper fuel flow.  I have done hat on all my 1A1 carbs when I remove the air box and use a Y boot.
Lyn Garlsnd
Mine already had a Dave F mod with an air jet instead of the brass ball. Thats why I blanked them
