DIY: Homemade timing tool
Started by quocle603, May 05, 2019, 09:40:22 AM
I saw that Mark. 200 for what I hope is just verifying. I will try and use the one I ordered.
I will set it the piston at 1.9 MM before TDC, mark the rotor as noted above by Chuck, use a pointer attached to the case and verify with the light.
Also,
good news about the timing light. I saw mixed ideas on what can be uses, some said needs to be 2 stroke. maybe that is only for showing RMPs and that will not matter on this.
Paul
Quote from: paul1478 on August 18, 2021, 01:16:43 PM
Also,
Paul
regarding the light, yes, pretty much its rpm readout is the difference. its nice to be able to offset the degrees on it though, for use with a programmable curve.. or on a distorbutor with advance system (car).
