Kawasaki G3SS Wont Kick Start
Started by Milan, October 11, 2022, 01:05:16 PM
compression. A low compression bike may run with enough oomf behind it. But, will be a bastard to start...
^ good point but lack of spark... might jus tbe dirty connections, im sure its something simple.
Milan
Is there some type of measurement or test I can do with the meter on the black ignition wire when not connected to the ignition coil.
To see if a get a pulse signal.
One lead to ground, other on black lead, kick over bike.
I should be able to see a voltage spike?
I tested the black lead to stator coil ground with the points open, and it was ok.
I will test again
it shoudl spike when the magnet passes over it. make sure the condenser is in good order and nothing grounding out down there.
Milan
So I re-measured the primary stator coil resistance.
I opened up the points.
Put one lead on the black wire.
The other to the stator plate.
I got 1.6 ohms.
Initially when my old eyes looked at the book, I saw Good = 5 ohms.
Not
When i re-looked with glasses i saw Good = 0.5 ohms.
so I am over.
That was with the old stator assembly.
When I did the same test on the NOS one, I got the same result.
So how could this even run with bump starting.
Now looking for a primary stator coil.
M
Milan
New coil supposed to be here today.
So I will have a go at replacing it tonite
I will test it prior to putting on, as well for the 0.5 Ohms or less.
M
