Kaw G3SS Lights
Started by Milan, November 14, 2022, 07:08:27 PM
Milan
Got the bike running.
The key gas 3 switch pisitions.
Off
Run
Run & Lights .
When running # switching to Lights .
The bike dies.
Battery is good & charged.
Bad connections somewhere.
Simple electric with the chargw,  lighting coils & a rectifier
m
do the lights come on w out it running?
should just be the tailight/gauge light coming on, headlight, if i remember correctly, only comes on when its running as one leg of ac goes to that, while the other goes though the single diode rectifier tot he battery. if thats the case, then see if it has the stock bulb in there.
Milan
Looks ti be stock bulb.
Wiring shows yellow as from the lighting coil.
I will disconnect & check voltage.
Also see if after disconnecting if bike goes off when ignition switch in Lights position
M
The third position is only park I thought? In other words the tailight stays on and the key can be removed. Bike won't run.
Bike should have a switch to get the lights on when in regular run position.
Milan
Wiring
( not too good resolution )
Off
Run
Run w/ Lights
my g3 didnt have a park position.  key has an off, run, run w lights as said.
Milan
Started it up tonight.
Adjusted idle a little higher.
Lights worked fine when switched on.
Adjusted idle back down a bit.
Still worked
Bike is ornery .
M
yup. idle at 1200-1400 ish should be ok
Weird, must not really remember then haha. Been a while for me and the G3.
