Coil question
Started by Czakky, May 29, 2019, 09:19:51 PM
I will try and post pics as soon as I can.
2t Fan
Hello
What plug wire i should use with Dynatek 3 ohm DC3-1 coils ? Which type connectors on either side ? bit confused
Cap will screw on, 7mm copper core wire.
2t Fan
ok, and code for the terminals to be used at the coil ens and cap end ? Dynatek wire DW-800 is ideal ?
rd400canuck
Quote from: Czakky on June 04, 2019, 12:20:31 PM
What became of this? I'm curious to know
Dyna high power coils are fine using static suppression wires, use copper core wires on most stock Yamaha coils.
I would buy the DW-1200 wire set not the DW-800 this way you don't have to buy/change plug caps to 90* degrees ones.
(when using static suppression wires DON'T use 5K resistor caps)
I do admit this is the only Harley part on my RD Yamaha! (they came with my dyna coils)
Quote from: rd400canuck on November 17, 2019, 07:57:53 AM
I had a seizure, eventually found it was due to oil starvation. I tried two different oil pumps rebuilt both of them, same issue in the left cylinder. I've now got a third oil pump at Chuck's to be rebuilt along with a whole lot of other parts.
2t Fan
Quote from: SUPERTUNE on November 17, 2019, 08:04:14 AM
Thanks...plug cap on it is suitable for nut type or stud terminal  ?
The DW-1200 use the tops with them, not the terminal stem.
C
rd400canuck
Thanks for quick reply :)
Scary how something like oil starvation can mimic ignition problems. These old two-strokes can be a real pain sometimes. I had an RD400G and it never ran properly after a complete rebuild. It was one thing after the next and it was always such a chore to try and diagnose it.
Pre mix is a pain and messy having to carry that oil around. I don't like it much at all. But what I like less is having an issue with an oil pump like you did.
So pre-mix it is.
rd400canuck
Maybe for the amount I will drive this thing... odd evening and weekend jaunt I might go the premix route as well. I could just have one of those little bottles under the seat ready and measured for a tank of gas in case I need it.
