Keihin PWK28 challenge!
Started by pdxjim, June 09, 2019, 09:19:05 PM
i think you'll learn the needles are different and jetting changes. i think Nick found that out, so calculate in the need for new needles as well. for example, the 'jjh' needles are pretty much the gold standard for rzs/banshees/rds but i -think- those come with 'nap-f' needles or ? something different.
:twocents:
Quote from: m in sc on June 11, 2019, 12:16:31 PM
:twocents:
Hmmm.  Thanks for that Mark.
Do the KX85 carbs come with the correct JJH needles and close jetting?
Still seems a bargain even with the added expense.
I bought a set of JJH needles at the local moped shop for $12.
Quote from: Hawaii-Mike on June 11, 2019, 12:40:20 PM
Yeah!  The scooter shop down the street from me has tons of Keihin and Polini jets/needles.
Genuine Keihin PWK28 KX100 carbs ordered from Bikebandit.com!
Thanks for playing, everyone.
Extra special thanks goes all the way out to tony27 in New Zealand for cracking the KX100 vs. KX85 code.
oxford
A little late but do the kx85 and kx100 have the same slides in them?
that i know, they do.
well done jim.  :toot:
bracket maker
I don't get it. why pwk kx and not banshee. I only see one part number but don't you need a left and a right to choke? also makes adjustment more difficult because on one carb the adjustment screws will be pointing the wrong way.
HAPPY TO BE HOME, 69-13 FTW,
..banshees never came with pwks.  and they arent hard to tune with 2 one sided carbs. also, you can drill and tap the body to accept the slide screw on the other side, ive done it.  :twocents:
Quote from: bracket maker on June 12, 2019, 09:30:10 AM
Banshees use early 70's tech VM series carbs.
PWK is a much more modern design.
bracket maker
#42
Quote from: m in sc on June 12, 2019, 10:23:14 AM
its not hard to adjust you just need to carry a screwdriver to adjust the idle. pita. so much easier with finger screws. hate this on my honda. I used a cable choke. would not do this again because I had to run cables. jim has to rig something so he can reach the choke on the wrong side.
genuine banshee vm 28mm's come in pairs drilled, tapped and hosed. screws pointing in the right direction. early '80's tech. they have an improved needle.
I'm a looser anyway. did the search keyword kx100 carburetor came back kx80/85/100 bootleg pwk's are $20, $38.80 for 2. I would have gone this route If I needed only one. for 2 I want a right and a left.
I agree tossing the original r5 vm28ss's unless you tap the main and move it out of the bowl. needle valve changes easy. '60 tech blows. nice when '80's needle fits the stock seat.
banshees had VM26's actually.
the knockoffs are huge risk, ask how i know. body not drilled right, needles of unknown taper, air jet orifice drilled tot he wrong sizes... been there, done it.
5 minutes with a drill and an m5 tap and you have a thumb screw on both sides of the pwk. cap the old hole with a short m5 screw and done. you just reach in and pull the choke up. I do this with the pj34s.  whats the issue? none.
Ummmm ... no (bracket maker).
PWK has thumb screws for the idle adjustment.  No screwdriver needed.  Plus, I just set them up at home using the Uni-syn or whatever.  Once setup, just use the adjuster at the throttle to speed up the idle if needed.  Also, if your sh!t is correct, once every thing is dialed in you only need to choke one side to start the bike.
The bootleg PWKs are crap.
You never get a right and left with aftermarket carbs off the shelf.  Most are easy to modify though (if you really think its necessary), or get carbs off a modern 2T twin.  KR1s, 1KT, etc were a good choice BITD, but crazy expensive and worn out by now.
