1985 Harris Performance (UK) Hand-Built 250cc Rotax GP Race Motorcycle - $5,200
Started by Guygrrr, July 09, 2024, 02:32:35 PM
finally got the prototype stuff printed and test fit.
finally got some of the parts made,going to hopefully move along faster now.   :burnout:
nothing extreme but this is a big step. got the shim depth sorted for engagement. need to machine the main housing down take about 38mm down. once thats done, need to key and tig weld the toothed gear on the shaft. lastly mount up the hydraulic clutch actuator. getting over a cold but this def made my day today.
bit of an update. big turning point, got it all machined and mounted. upside: it all works! downside.. I need to add a compression release. even w a 400cca battery the compression is just too much. but I have a plan. regardless,  got the battery box etc all fabbed up. still zero permanent mods to the bike itself. all bolt on.
RDnuTZ
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
How fast would that starter theoretically turn the motor (unloaded)?  It may need to be geared down further to get more torque multiplication.  I don't recall the AF1 ( same motor) being hard to start.
its staying as it is, going with a compression release.  that motor is reading 170 psi cranking compression. also its driving the clutch basket.  testing on the crank end was no bueno. there's no feasible way to change the gearing tbh
RDnuTZ
