Rd350: 100/90 18 vs 90/90 18 front tire
Started by MRDRcycle, January 02, 2025, 11:58:32 PM
Quote from: busa1300 on January 03, 2025, 09:38:08 PM
Quote from: Yamanatic on January 03, 2025, 10:29:39 AMThe 100/90 Avon on the front is a very tight fit. I put a 100/90 on the front of a '73RD and had to let the air out to get past the fender bolts. Ended up putting the 100/90 on the rear, and a 90/90 out front. Looks better too, but that's personal taste.
How are you getting hooked up with Avon tires ?
Been looking for 130-70 and 110-80-18's for the Dymags on my RZ for a few years now.
Randy, no personal experience buying bike tires through Summit (although I've bought a shitload of other stuff from them) but following the tip from Tim above I did a search and these popped up:
https://www.summitracing.com/search/part-type/tires/product-line/avon-tires-roadrider-mkii-tires?N=tire-size%3A130-70-18_110-80-18
grcamna3
Quote from: Dvsrd on May 05, 2025, 04:38:51 PMWouldn't a 100/90 be just too wide for a stock RD350 rim?
Can't say I am 100% sure, but aren't the stock rims something like 1.60" and 1.85" wide?
Using wider tyres on narrow rims won't give the correct tyre shape.
Does MRDRcycle have stock-width rims on his 73' RD350 ?
RDryan
I just recently put a set of Shinko SR712R's on my RD250 with stock wheels.For sizing they read out on the sidewalls as 3.00-18 for the front which I believe translates to 80/100-18 and 3.50 for the rear, translating to 110/90-18...and I would just like to give Google credit for those standard to metric conversions. :whistle:  Not sure why Shinko uses inches to indicate tire sizes but it is what it is. :huh:
They don't have that beefier look I see on Warren's 350 :olaf:  but they also don't have those awesome shouldered Aluminum rims. :'( I'm jealous...My Shinko's on the stock wheels just look proper and the bike handles great.
Good solid set of affordable tires I would say about those Shinko 712 series. My second one for the rear and a first for the front which did replace an Avon. I'm no expert on RD's or Avon's or even Shinko's I just buy what I find on Ebay, the best bargain.and even though it probably didn't need em I did get a set of new tire tubes as well.
Not sure what's so great about Avon's....in no particular order I just want proper date coded tires,correct size as designed by wheel maker and value. Just say'in.  :whistle:
My one 400 has a 110 rear and the other has a 100. Both have the stock rear wheels (1.85) The 110 has 1/4" more width of tread than the 100. I ride then about the same way. The wear shows that the 100 is using 1/4" more of the tread. The 100 is putting more of the rubber on the road.
