Fork Questions…
Started by AAAltered, February 04, 2025, 01:20:33 PM
RDnuTZ
I found Emory Cloth strips works better for those than steel wool. You can get rolls of ~1" Emory in different grits and cut off like 6" sections and rub/pull back and forth around the fork tube to get the high spots down and lighten the black color. Sometimes a little oil helps too. Then hit with carb or brake parts cleaner. Rinse and repeat until smooth as you want them. Then I hit with "Chrome" or Aluminum/Silver color Rust encapsulating spray paint. I Never thought of Mark's great idea of using the paint pen, but will have to try it  :thumbs:
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
2T5
Quote from: RDnuTZ on February 16, 2025, 09:56:53 AMfound Emory Cloth strips works better for those than steel wool. You can get rolls of ~1" Emory in different grits and cut off like 6" sections and rub/pull back and forth around the fork tube to get the high spots down and lighten the black color. Sometimes a little oil helps too. Then hit with carb or brake parts cleaner. Rinse
I know of a mechanic who used this as standard procedure whenever replacing fork seals.
