the 72 T500
Started by m in sc, April 11, 2025, 10:06:53 PM
generic muffler straps from Amazon, stainless,  for a secondary mount round the pipe body. think these were 100mm. actually, work really well.
2steve
And here I am using zip ties on the RD400 FPPs because they were made for a DS7. I think those straps would work regardless of the top and bottom weld flanges.
Excellent, Mark.
I have done something similar. Ended up just getting some bar stock aluminum and making my own brackets. Cost me 7 dollars.
they would. i went with these because, well, they were cheap, and rubber isolated. good thick metal though
They look a lot better than the hack job i did with some rubber straps and pipe hanger metal.
 :clap: Those look good and should do the job well
Quote from: quocle603 on September 23, 2025, 09:18:56 PMThey look a lot better than the hack job i did with some rubber straps and pipe hanger metal.
gargantua350
A rubber washer between two metal washer doesnt isolate the vibration enough?  I had to do that with my old SPEC 2s on my RD400 as the welds cracked at the mounts.  I do that to all my pipes now.
Vintagewannabe
Quote from: m in sc on September 17, 2025, 10:15:41 PMthey didnt stop. fast from the past did.
so who is importing? Google didn't turn up anything but HVC and fast from the past, and like you said they quit.
Quote from: gargantua350 on September 28, 2025, 09:28:35 AMA rubber washer between two metal washer doesnt isolate the vibration enough?  I had to do that with my old SPEC 2s on my RD400 as the welds cracked at the mounts.  I do that to all my pipes now.
Great tip.
I went ahead and replaced the bars with some i won at a raffle at a bike show in Piedmont,  sc last weekend . I was trying with goung to taller bars but these basically fell into mynlap. they are a bit more pulled back then the bars I had, same pull back as stock t500 bars, almost 2" lower but 1.5" taller than the ones I had. pretty sure they are for a vintage Bonneville.  I cut 1" off each side and are actually.. perfect. new bars on the bike, 3rd pic is stock t500, last is what i had on the bike.
