Yamaha RD400F refresh
Started by SoCal250, May 16, 2025, 11:53:34 PM
0 Members and 8 Guests are viewing this topic.
Quote from: Kawtriplefreak on August 11, 2025, 11:59:23 PMBeautiful work!!! :patriot:  :patriot:
Thanks Tim :cheers:
Just trying to somewhat keep pace with the goings on in your shop (but I seem to be drastically slipping behind) :dawg:
I am still working at it...one day that shop will be cleaned out and organized. It has come a long way but has a long way to go.
RDryan
Quote from: SoCal250 on August 11, 2025, 08:50:37 PM
Quote from: RDryan on August 11, 2025, 08:25:05 PMAhh I see that makes perfect sense. Duh, I have my stock RD so I should know that about the caliper location.
And just an FYI in case you're getting any wild ideas :dawg: if you switch fork legs to move the caliper to the rear you'll end up with the speedo drive on the wrong side and spinning backwards, bringing all the issues that entails. :twocents:
OK good to know :thumbs: I would love to do that someday but for now my RD doesn't scare me enough to be wanting more stopping power.
350GUY
Quote from: SoCal250 on August 09, 2025, 06:26:16 PMRealized I never posted the before/after shots of the right side of the engine since I was still working on that when I posted the left photos back in May.
BEFORE:
AFTER:
And how the bike looks now following all the recent updates during the refresh.
Very cool! Has anyone tried the clear clutch window mod on the RD350?
Over the weekend I swapped out the old chain & sprockets for a 520 upgrade.
While I was in there I replaced the CS seal and neutral switch O-ring, as there has been a recent oil drip from the area.
(Note: Photos were taken before I hade done final torque or cut chain to length.)
I need to go back and redo my safety wire on the rear sprocket because after it was fully assembled I discovered why the previous owner had tied the wire on the wrong side of several nuts. It needs to run on the outside of the nuts because otherwise it tends to rub on the wheel spacer.
