YPVS Loses Position(?)
2steve and 1 Guest are viewing this topic.
29L2626000P: CABLE ASSY, THROTTLE & PUMP (NON O.E. ALTERNATIVE) Yamaha - buy the 29L-26260-00P at CMSNL https://share.google/mPX8Pwz6VFQaW3cNQ
2steve
#301
Got it. Thanks!
And the Norway only country choice just gave way to include USA, so it's on order.
automan
2steve
Removed the stock RZ throttle cables and installed the recommended split one from CMSNL. Next step is swapping the RD400 carbs in.
2steve
Maybe there's a part that will get me from the RD400 carb top to the new split cable end?
The long straight hex does not come off and the plastic liner sticking out won't budge.
Looks like a 45° would be good with male threads at both ends.
Mikuni VM TM Style Carburetor Angled Top Cable Elbow Adjuster I-M22-10-3 | eBay https://share.google/NfVVEKDspZwyVuujp
2steve
automan
2steve
The 45° carb cable adaptors are in.
The cable ends won't start to fit through though.
I'll do a compacting roll on the ends this weekend in some improvised way to get the diameter down. Should work after that.
Other things going on. Dryer needed new parts and there are grandkids. I'm slow. Not having to work would be a bonus.
2steve
45° adapters are a problem. Trying to make them work caused me to ruin a cable end. The original RD400 cable is closer to fitting through, but the real problem here is the ID of the 45's tube being too small. I don't have a 45° drill bit.
The solution would be to feed the bare cable wire through and then melt on some new ends.
I don't see a solution.
thats tricky for sure.
