Front Rotor - RD350B
Started by 350GUY, September 28, 2025, 04:53:11 PM
oxford
350guy, I thought about it last night after I posted, I might be giving you wrong info on what you are wanting to do.
 The TX lowers are the forks to get dual disc on a RD but I think you are going to have the same speedo problem as with flipping factory forks around for the caliper in the back.  You will just gain the caliper on the same side as stock.  Sorry for the confusion.
TX500 forks have caliper mounting lugs on both legs and the full assembly is roughly 1.5" longer than RD forks. The right side lower is the same part on the TX and RD. Lowers are interchangeable.
A left fork slider from a '73-74 TX500 can be swapped in to replace your OE RD350 lower. That will give you a provision for mounting a caliper on the other side (in front of the leg). As mentioned above if you swap sides with lowers to move the caliper behind the fork you're going to lose the speedo drive function.
371-23126-60-00  FORK TUBE, LOWER LEFT    TX500, TX500A, XS500B
351-23136-50-00  FORK TUBE, LOWER RIGHT  RD350, RD250B, TX500, TX500A, XS500B
AFAIK, the only 34 mm Yamaha forks with the calipers behind the sliders are 1976 XS650C and pre-Daytona RD400.
The XS sliders are a bit longer than RD sliders, and also have larger OD.
The RD400 sliders are also different from the 350 ones,in the top end/ seal area. So best replaced as a pair.
350GUY
Quote from: oxford on November 30, 2025, 07:51:35 AM350guy, I thought about it last night after I posted, I might be giving you wrong info on what you are wanting to do.
Thank you Oxford guy for clarifying, know that it is appreciated.
350GUY
Quote from: SoCal250 on November 30, 2025, 02:38:26 PMTX500 forks have caliper mounting lugs on both legs and the full assembly is roughly 1.5" longer than RD forks. The right side lower is the same part on the TX and RD. Lowers are interchangeable.
Thank you very much SoCal for sharing these deets, this is extremly hepful.
2 Smoker
Quote from: oxford on November 28, 2025, 08:38:00 AMHere is some inspiration if you are still going the OEM route.  100 3/8" holes per rotor and they were also thinned down to around 5mm.
Simply stunning
I have a blue dot caliper here somewhere that I bought for our RD350 drag bike.  I used an alloy repo caliper with alloy pistons instead.
oxford
Quote from: teazer on December 12, 2025, 03:20:15 PMI used an alloy repo caliper with alloy pistons instead.
That is what's on the bike with the drilled dual rotors I posted on the first page.
