RD400 Project
Started by Aaron Russell, October 11, 2025, 12:58:03 AM
That height is 3 1/4"   The hoop is .210" thick and about 1 1/2" front to rear. The width of the hoop is about 6 1/2"
Aaron Russell
Thanks for those dimensions, they ended up working for my hoop.
Been making progress slowly but got everything welded up that I needed and got most things powder coated. Today I got the motor back in.
My fork tubes ended up being slightly bent, I didnt take them apart previously because I was having trouble getting the damping rods out, ended up hammering one of those "universal" sockets down with a T-Handle to stop them from spinning.
While I had them out I installed MikesXS valves, new tubes, adjustable fork caps, and new seals and hardware.
Aaron Russell
I finally got around to modeling up a rear brake conversion I've been planning for, an underslung brembo p34 with a 245mm disk, got everything mocked up and ready for machining after a couple more tweaks.
i like the split chain adjuster.
looks good.
Aaron Russell
Quote from: m in sc on May 28, 2026, 04:44:45 PMi like the split chain adjuster.
looks good.
Thanks,
Made them 2 pieces so the right side adjuster can adapt the larger hole the original hanger sat through.
Thanks,
[/quote]
Fantastic detail!
Aaron Russell
#21
Final parts came in today :)
Everything with the caliper (except brake stay arm) weighs 5.25 pounds, ill weigh in the stock setup when i get the chance.
Made up some chain adjusters for my 1980 YZ125 as well while I had my order in.
stresa
I like that.  :olaf:
Very smart parts.
Regards Uwe
81 Jackson 250,2x 74 RD250 racer,78 RD400 2R9,77 RD400 1A1,72 R5/RD350 rat,74 RD250 streettracker,75 Yapol TZ250,3x 76 TZ2/350,89 Honda RS125,
80 Hejira PE250,77 Höpfner-TD3,76 RD/TD3,75 TZ/RD250A,78 Siroko TZ250,86 Tomic 200,91 TDR250,86 TZR250,2x 94 FZ750,86 FZ750/1000,99 TDM850
Aaron Russell
Old setup weighs 13 pounds, so nice little 5-6 pound savings.
The funny part is the old stock rotor weighs 5.5 pounds
