Rd250 Honda headlight led
Started by Ballas03, July 05, 2019, 06:17:14 PM
JakeS
#15
I took a stock rd350 headlight and put an led bulb in it. You have to take a screwdriver and bend all the ears that hold the bulb part in.  Take the washer and o-ring out. Then I used a pair of pliers to pull out the filament. It left a thin glass bulb in side the lens. I used a screwdriver to break it up and dump it out. I then took a cheap H4 LED I had and cut the ears off so it matched the size of the washer that I removed. Put the bulb in them o-ring and last the washer tap the ears back down to seal it all up and you have a factory lens with an led bulb.
When I figure out how to resize my photos I will post some pics.
