Ignition booster for Points RD350
Started by Pravin, November 01, 2025, 07:51:59 AM
Pravin
Hi all ,
Anybody has tried using ignition booster/amplifier for increasing spark density ?
Am going to increase the compression of my bike keeping the points ignition which kind of doesn't work well on high compression engine and I don't want to go CDI route .
Something like this ?
https://ebay.us/m/2tTGBw
Please suggest.
Cheers
Pravin
Pravin
Quote from: m in sc on November 01, 2025, 08:03:43 AMget a hotter set of coils.
Hey , how can I decide on hotter coil ? Any specific values ? We have 4 ohm primary and 13k secondary coils in India came with bike
im not sure w the radjoot ones were rated at.
Many years ago, we used to use transistor assisted ignitions.  The idea was that the points would be subject to a much lower load to just switch the transistor and the electronics would carry the load. To be honest, I can't say that any change in performance was noticeable.  Maybe try a relay in the coil power line to get full battery voltage to the coils.  That won't help your points last any longer but should potentially provide a stronger spark.
You could also try a set of Chinese DYna clone ignitions.  I am a fan of Dyna and not of companies copying their IP but you are a long way from here and that might be a suitable solution for you.
Im currently using the Chinese dyna. I had several real dyna burn up due to leaving the ignition on. Works fine and it was a fraction of the cost.
Quote from: quocle603 on November 02, 2025, 08:04:39 AMIm currently using the Chinese dyna. I had several real dyna burn up due to leaving the ignition on. Works fine and it was a fraction of the cost.
Funny you should mention that.  I was setting up a custom DYNA for a GT550 triple and three genuine DYNA modules let the blue smoke escape as I was setting the timing.  Not all at one though.  One dies so it was replaced then a different unit died and was replaced.
Copycat units, no problems and  what appears to be a fatter spark on the tester.
That was a pretty common with Pertronix pickups too. Leaving them on was asking for it. Pertronix fixed that like 15 years ago.
