Need help on project
Started by Tropic-al, November 19, 2025, 10:15:47 PM
RDnuTZ
Do you have a manual? I never start into a new project without 1 for easy reference on stuff like this.
:twocents:
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
RDryan
I know the numbers can be hard to read on jets and I would suggest if you haven't got one already, get a magnifying glass. I used to try to wing it without and I finally gave up last year, what a difference it makes to have one. Mine is just a cheap hand held with two optics lens and a led lamp that really helps :twocents:
https://www.nichecycle.com/categories/carburetor/mikuni-parts-by-category.html
175 is the series type of the nozzle. There should also be a size of P-2 stamped on it too. That is the stock size for a 400 carb. Main jets should have a number on them too, if not, get some that do. About a 120 for a completely stock bike.
Tropic-al
Thanks to all that pitched in to help. Just to clarify your concerns and advice.
I bought a nice manual that includes 76 to 79 RD400 models. Unfortunately the only spec list I looked for at the end of the manual, only had RD400 F specs. After your reply I tried harder and found an Appendices list that included all models. So, now I have the jet sizes I need, able to read it with a well used magnifying glass. LOL!!! Still, my big problem is I need 1 of the P-2 needle jets as the threads for the main jet are messed up. I'll check Niche and Yambits as they seem to be the only ones that might have one.
If a member here would have one for sale, I would definitely buy it.
Thanks for the usual concern and advice to a new member.
Andrew S
Niche Cycle on eBay has the 175 series P2 needle jets.  And they're located in Florida.
https://www.ebay.com/itm/162266775249
Look over the jet needles closely as well, if they're high mileage, the anodizing wears away and fueling profile changes drastically.  Niche has stock 5L1 jet needles too.
https://www.ebay.com/itm/161063800187
Tropic-al
Thanks for the reply Andrew. Niche did not have it when I contacted them but Economy Cycles got me both things. They just arrived yesterday.
NYSingh
Quote from: Tropic-al on April 13, 2026, 01:13:38 PMI bought a nice manual that includes 76 to 79 RD400 models. Unfortunately the only spec list I looked for at the end of the manual, only had RD400 F specs.
Sharing a few resources from my Google Drive that might be useful:
Moto Guzzi V7III
Tropic-al
Thank you Singh.
Lots of info I didn't have.
