Thanks Gil. The 500 badges are misleading on purpose. It is a late 71 bottom end with 72 cylinders, H2 750 engine in a 76 KH500 frame.
New fancy rearsets. Everything is adjustable, up, down, forward, rearward, petal length, petal leverage. The master cylinder seems to work good. Ball bearings on the petal pivots. Haven't tried them yet, next week when I get the motor going again.
pegs1" border="0
pegs2" border="0
After my 19 year old CRG bar end mirror glass departed the aircraft uncommanded and shattered in the road I replaced it with a cheap Chinese bar end.
I will likely order a replacement glass as they are still available from CRG.
It was a bit odd to install as you have to hold all the pieces together while tightening the part that goes up against the inside of the bar and slide it in just shy of it being too big to go into the bar and then continue to tighten. There was no screw to turn you turn the whole stem. Eventually I figured it out.
Ohhh its one of THOSE bar ends. i thought tit was a different type from the text you sent. yeah those can be fussy.
Flogged her good on Thanksgiving Day.  This bike LOVES cold air.  It proceeded to spit gas on the garage floor when I parked it...
busa1300
The RZV is up on the table for some exploratory surgery
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
"Exploratory surgery" never sounds good! I hope it's nothing more serious than a missing sparking bolt.
nothing terribly exciting, resurfaced bowls on t500.. they were indeed a bit warped,  drilled screw holes out to 4.5mm (lets bowl align a bit better))and chamfered edges of holes. also added a double gasket as they would seep a bit when on sidestand.. super annoying leaving that brown fuel stain.  cleaned up intake hardware to stainless studs as well. just.. maintenance.
Layed up the R5 in the shed to make way for the.....snowblower in the garage.  It did remind me though that it's leaking fuel when the petcock is on.  Petcock, floats, dunno and won't until spring.
AAA, I think I would winter that one up in my spare bedroom!
Yea that's not happening.  At least the bikes in the shed are covered and mouse baits set.
Beside the snowblower I need room to work on the RD200 in the garage.  More on that when I bring it in...
Swapped the RD200 into the shed and pulled the R5 into the garage to make some fixes.
1) Tach is making a new noise.
2) Gas leaking which of course means repaint the chambers but that's ok.  Found the bowl nut on the left side less than finger tight lol and that was the leak.  Good thing my wife likes the smell of gasoline.
3) Pulled pipes off for stripping and repaint.
4) Scheduled a gear oil change while the pipes are off.
5) Chance for a good cleaning of the underside, it's pretty greasy under there.
6) Fixed a throttle problem, the grip had crept over and was binding a bit on the housing.  Grips feel pretty gross and sticky, they are a few years old so I'll be looking at options.
You guys south of me riding this week got me motivated to get maintenance done.
busa1300
#478
Spring cleaning of the carbs. Hopefully only once this season, they are a real pain in the ass to get to and pull, then get it all back together.
Also checked my plugs on my TM400/TS400... look pretty good so far. Still feels like it should run better though.... No where near as scary as all the stories I've read.
2 Smoker
Quote from: Kawtriplefreak on September 10, 2022, 11:56:30 PMThanks Gil. The 500 badges are misleading on purpose. It is a late 71 bottom end with 72 cylinders, H2 750 engine in a 76 KH500 frame.
Quote from: 1976RD400C on September 11, 2022, 07:56:27 AMNew fancy rearsets. Everything is adjustable, up, down, forward, rearward, petal length, petal leverage. The master cylinder seems to work good. Ball bearings on the petal pivots. Haven't tried them yet, next week when I get the motor going again.
pegs1" border="0
pegs2" border="0
I just purchased a set for my RD 350 I hope they are going to function well with all the adjusting ability i hope they will fit the bill.
