FZR Bits on RD
Started by SmokeAddicted, June 02, 2026, 09:48:07 PM
Did someone mention TZ top ends on air cooled cases? Back in the day, TZ cases used to wear out and replacements were not always available, so racers took to modifying RD cases to take the TZ crank arrangement. Others bougt TZ top ends and fitted them to RD bottom ends.
This is a set of RD cases with a TZ crank and water pump with RD400 transmission and 40900 (64mm bore) top end with bigger reeds. 40970/40971 66.25 TZ750 C/D/E top ends also drop straight an to an Air cooled bottom end.
I forgot how to insert and image.  I'll be right back as soon as I work that out.
I worked it out  :whistle:
