RZ350 Flasher
Started by 2steve, August 01, 2026, 06:12:19 PM
2steve
When riding the RZ350, I notice that the LED headlight pretty much blinks when the signals are flashing.
Thinking it through and checking some things, I decided to pull the flasher relay box apart. It looks original.
There's no way it is not suspect when I see a sizeable capacitor in there - from 1985. It's pulling the voltage down for the headlight on a separate fuse.
With the signal canceller that hasn't worked except one night when I was riding home from Rock Hill, I think I'll give up making it work and go with another option.
The RZ unit has 3 prongs in the shape of what looks like an H4 headlight plug.
Is there a quick drop in? Maybe even a known digital flasher that doesn't care if the bulbs are LED or incandescent that fits the plug?
just run an automotive one. 2 prong is fine. the 3rd one is s ground a newer one wont need
2steve
The Novita Flasher LL552 plugs in and works much better.
I also "rebuilt" the original with a new capacitor and resistor.
It will be a spare or I'll put it back in to see if the self canceling will work again.
Had to order (100) 150 ohm resistors  :busey:
Got 99 left if anyone needs a replacement.
