Testing for Charging Issues
Started by BlueR32, September 09, 2026, 08:31:07 PM
axldk6
I just recently ,like 3 weeks ago, bought my Vape from John@Economy. yes it is pricey ( about $ 280/290 is just tarriff taxed  :eek: ). do buy the upgraded retaining bolt, a new grommet , and I bought the 2 coil brackets , though I could have made it work without. be carful routing the neutral wire too. took me about 1/2 a day to get it up and running. fyi, I marked my timing mark in case I need to pull it back off , for like a pinched neutral wire  :whistle:
been wrenching for many years, still need help some times
1974 RD 350A ( full project bike)
2002 Kawasaki  ZRX 1200R  ( 99% complete)
axldk6
and use the discount code ' 2SW' saves some $.
BlueR32
#17
Quote from: axldk6 on September 16, 2026, 08:37:36 AMI just recently ,like 3 weeks ago, bought my Vape from John@Economy. yes it is pricey ( about $ 280/290 is just tarriff taxed  :eek: ). do buy the upgraded retaining bolt, a new grommet , and I bought the 2 coil brackets , though I could have made it work without. be carful routing the neutral wire too. took me about 1/2 a day to get it up and running. fyi, I marked my timing mark in case I need to pull it back off , for like a pinched neutral wire  :whistle:
I'm about to pull the trigger on the Vape kit from Economy. Curious about the coil brackets for the Vape coils though. Looking at the coil bracket pics on Economy website I can't visualize how they mount to the frame. By the way this is for my SRX/RD250 project where I modified the original RD coil bracket to span across the frame (hope the pics show this clearly). Would I be wasting $$ buying the coil brackets in my case?
BlueR32
I found some more detailed pics of the brackets on the HVC website. The brackets clamp around the top frame tube on a stock RD frame. I don't have that center spine tube so I will have to figure out a different mounting arrangement.
ive used heavy duty p clamps just run a separate ground
BlueR32
Quote from: m in sc on September 13, 2026, 08:25:25 PMif you order it thru economy cycle make sure to get the relay.(i think he includes it).
post when you get it, i have a few tips.
The Vape Kit arrives tomorrow. Interested in your tips, pray tell :help:
RDryan
It's interesting, when I got my Vape from HVC they never had those coil brackets. Oh well.
heat the rotor to 220f when its time to install, tap on w a dead blow, thrn zip the nut down when its time.
[/quote]
Take all the fasteners apart and put blue locktite on all of them before putting it on the bike. It gets expensive fast if something comes loose while running
bitzz
Quote from: m in sc on September 29, 2026, 09:00:49 PMheat the rotor to 220f when its time to install, tap on w a dead blow, thrn zip the nut down when its time.
Two things a magnet doesn't like: heat and percussion
Lap the rotor to the taper using valve grinding compound, then tighten the nut slowly and torque it.
well a single gentle wrap with a deadblow is fine, and 220 won't affect it. needs to get over 400f to affect these.  its an interference fit, no need to lap unless there's prior shaft damage. im running them on 6 bikes right now. one since 07. yes beating on it with a ball peen hammer a d putting it on broil is a bad idea.
BlueR32
[/quote]
Are you talking about the three components of the stator that need to be taken apart and loctited?
BlueR32
Quote from: BlueR32 on October 04, 2026, 12:50:42 PMTake all the fasteners apart and put blue locktite on all of them before putting it on the bike. It gets expensive fast if something comes loose while running
Quote from: BlueR32 on October 04, 2026, 12:52:36 PM
yes, and dont overlook the pickup. get everything setup and then check pickup gap before locktiting those
axldk6
#29
hey BlueR32, did you get it installed yet? those m3 screws that hold on the pick up will strip so damn easy, guess why they send ya 2 sets. I advanced my timing to 1.9ish mm BTDC  because of the hotter spark. I also used a protractor to get that 1* on the nose/raised section and marked it . 15 ftlb on the retaining nut if you bought the upgraded bolt/washer .
