RD350 exhaust options.
Started by PhilMill63, October 16, 2026, 03:25:39 PM
PhilMill63
What are guys who have put 350 top end onto later RD250s using for exhausts? Will 350B front pipes go into later pipes/chambers? What are my options, bike is a '79 250E with 350 cylinders.
Thanks.
cant speak to the e models but the 75 and back 250/350 exhaust interchange with the only diff being the baffle.  they sell reproduction (and better flowing) 350 baffles that slide right in
id imagine the mounting is different..?
PhilMill63
It's totally different, different height and angle. I guess I'll be having a set of chambers made to fit. I was hoping somebody here may have found an alternative.
RDnuTZ
it would help if you mentioned what country you are located in and picture or 2 of the bike you're talking about.
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
PhilMill63
Quote from: RDnuTZ on October 17, 2026, 10:16:36 AMit would help if you mentioned what country you are located in and picture or 2 of the bike you're talking about.
The bike is in UK but I spend my time between Florida and UK. Will try and post a picture of how it was when I bought it.
PhilMill63
Here is bike as I got it.
i would bet you could use 350 aircooled headpipes with the stock mufflers and probably use the repro 359 baffles in there
PhilMill63
Quote from: m in sc on October 17, 2026, 07:05:59 PMi would bet you could use 350 aircooled headpipes with the stock mufflers and probably use the repro 359 baffles in there
Thats something I had considered, thanks.
