6 speed RD400 close ratio transmission in a 6 speed RD350
Started by SUPERTUNE, July 20, 2019, 11:06:25 PM
You should not need sealer with the oring.
I put sealer on the key and both side of the key way on motors with out the oring
if you have the oring IMHO theres no sealant needed.  :twocents:
Greaser Greg
Quote from: rodneya on December 18, 2020, 02:42:40 AM
Does that mean  on motors where there is no groove in the crank for o-ring, or you substitute sealant and skip the ring even if there is a groove? :cheerleader:
Quote from: Greaser Greg on December 19, 2020, 01:07:16 PM
Yes, RZ's and banshees never had an oring
bhh1989
What about the full swap into RD350 center cases but with an R5 clutch cover - would you still need to do any grinding on the inside of the cover? I am using R5 side covers just for the aesthetics of them.
Same thing. A few mms need to be ground off or some double up gaskets.
