Help! with a Dyna S
Started by AAAltered, August 04, 2019, 04:12:59 PM
2t Fan
Quote from: AAAltered on August 23, 2019, 07:42:57 AM
^^^^^^^ what he said.
BUT instead of buying a new VS kit, I bought a KZ kit for $120 and used the pickup.  The real cost of the VS kit is the custom made mounting plate.  Once you have the plate, you can use pickups from other kits.  I researched all the Dyna S kits and had to go by them looking the same, since there are no PNs on the bits.
I'm glad I finally dug in to resolve this, I didn't originally install the iggy so had little knowledge about it.  Now I do and got away "cheap"....
i was planning the same route. Later decided for a complete kit when Nick suggested that problem can be of the trigger also, which is not available in spare
Nick's trigger has three magnets. The extra magnet is what prevents it from running backward. You can test the magnets with a small Allen wrench or paper clip. The three magnets are pretty close together. With the Allen wrench or paper clip, you should feel three distinct and equal pulls from the magnets on the rotor.
2t Fan
Quote from: Organicjedi on August 25, 2019, 11:07:51 PM
Thanks for that info
Oh man, I had the same issue and needed to get a new mod as well.
