Powerdynomo CDI upgrades and install (Vape)
Started by SUPERTUNE, August 11, 2019, 09:07:48 AM
I hope I make the Supertune video library next spring. :clap:
rd400greenhorn
thanks a million chuck, i will try to follow this on a few weeks when i hopefully get the ignition done.
Baldwin53
Chuck, it was good to visit with you last week. I am always impressed by the depth of your knowledge and the meticulous care you take with everything you work on. It has been further demonstrated by the time and detail that you put into this post that unselfishly helps everyone else.
Good job my friend!
Quote from: Baldwin53 on August 13, 2019, 02:49:52 PM
Good job my friend!
Thanks for the nice comments sir.
It's all about US, not just me, the 2 stroke community is all about friends, family and loving our dream bikes!
C
Good job my friend!
Well said Sir!
AtLarge
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1994 BMW K1100RS
2023 Honda CRF300L Rally ABS
Here's some Extra Info from members here on the relay setup wiring I added...Chuck
Thank's guys!   :clap:
Comments from DVSRD...
Use a regular automotive 5 pin relay. Connect the blue wire to pin 30. Connect pin 86 AND 87A to ground. Connect the original 12 volts supply to the stock coils to pin 85. Then it works.  Pin 87 is NOT used!
Comments from m in sc
#30 and #85 should go to ground  (30 is to operate the relay - power feed, 85 is 'signal' the coil receives)
#87a should go to the blue coil wire (this is the normally closed pin, this grounds with lack of power to the relay)
#86 should go to 12v switched power (this is what powers the relay when you turn the key on to unground the coil)
#87 is not used. (this is the normally open pin. do not use in this application)
Or as DVSRD stated, basically the same thing. MAKE SURE when you turn the key on the relay clicks. if it doesn't, check your 12v supply to trigger the relay, and the ground.
its literally a $10 retail part off the shelf.  its in the electrical /lighting aisle. But it has to be a 5 pole.
https://www.onallcylinders.com/2015/01/02/relay-case-whys-hows-using-relays-automotive-wiring/
motulman
hey chuck its been a long time,  does this installation cover the daytona also?
Quote from: motulman on July 07, 2020, 08:00:39 PM
Pretty much the same as RD400's, the difference with a Daytona model is the headlight signal relay yellow wire from the stock stator.
I don't remember what I did exactly...I think I just may have jumped the relay in the headlight shell to turn on with the key and not use the relay.
motulman
thank you for your reply,  yea ill be on this installation for i bit i think
motulman
chuck what was the reason for the pookey on the gen wires?, did you shave the edge off the  stator mount where the wires go through?
motulman
hey chuck what do you do with the ballast resistor? is it used? its not mentioned in the vague instructions and i dont think you mentioned it either
you dont use the 400 ballast resistor with the vape at all. you can use the unresisted feed wire into the resistor to power the relay.  the silicone on the back of the wires is to reduce vibration/chafing issues you may have.   :twocents:
motulman
Quote from: m in sc on July 18, 2020, 11:42:42 AM
thank you so much m sc
motulman
 so...you just bailing wire the other end of the coil?
