Crank nose Play and Points Timing
Started by Pravin, September 01, 2021, 10:07:33 AM
bitzz
Quote from: teazer on September 02, 2021, 10:26:52 AM
Why do I recall a post somewhere that said that CDI cranks had the keyway 90  degrees different to points cranks?  Of course I can't find that posting now or remember who posted it.. :whistle:
Someone should know the answer, but it should not be hard to re-clock the points cam.
The CDI RD crank was a RD400 and the Rd400 CDI had a keyway that was 90 degrees off  the later RD-LC and RZ CDI models.
The CDI cranks also had a different taper from the points models.
Pravin
Thanks Bitzz for outing some light
Indian RDs are basically RD350 A what you guys have  there ..
Same crank , the one in my videos .. already in the engine is indian crank adn the spare one at home us USA one  both are interchangeable , am using usa crank on my cafe with MZB
Cheers
Pravin
you checked the keyway clocking vs the 2 cranks?  :umm: :whistle: im thinking thats where the disparity is.  either way, reclocking the points cam is the easiest solution at this point.
Quote from: Pravin on September 02, 2021, 07:45:46 AM
Got my crank balanced today ....with bearings on its withing .03 to .04
Hope am good , will install it and see if am getting any help in timing ..
https://youtu.be/I-ELqBrpo3A
Regards,
Pravin
0.03 to 0.04 mm I hope?
