I will need a set of gauges for my bike.. before I go and buy some I was wondering if the yds7/R5/RD share the same tachs and speedometer. or are they different?
Thanks
ds7 and r5 are same.
rd 250/350/400 will function. all ratios are the same across yamaha and kawasaki.
i actually have these on another bike and they are fantastic.
on www.partsnmore.com the matching tach is: #03-0759
the speedo is here on partsnmore, cheaper too.
#03-0760
YDS7 and R5 are identical. RD has different, angled input shafts.
(https://i.ibb.co/GV7yC7P/62-F99837-2-F28-4-D7-B-8-C4-D-3-B1-CBEA73943.jpg)
(https://i.ibb.co/stTYBSM/96-DDD115-EA4-F-4-F2-B-B1-CB-9-AE329-C42877.jpg)
i dont have any close up pics but here they are on my t500. they are 99% the same size as an r5 gauge.
I painted the housings with wrinkle black.
(http://www.2strokeworld.net/wp-content/uploads/72-T500/20200523_174512.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-T500/20200523_194624.jpg)
Thanks AAAltered. That is one of the questions I had.. Was not sure which I needed.
Quote from: m in sc on February 24, 2021, 10:34:06 AM
#03-0760
Wow they are cheap. And look good too.
How did you mount them?
stock bracket just opened it up a bit. would work on r5 mount as well with a bit of finesse . oh side note.. those are spare R5 rubber rings around the edge of the gauge. ;)
Now it can do 130, right? :haw:
105. the extra 25 is for downhills and drafting :dawg:
Mark, might those gauges fit the stock RD? That's tempting as hell.
the cable input isnt angled but you can make anything work if you try hard enough. :haw: :science:
