Damaged DG Perf 4 Heads
Started by rlgrantjr, October 02, 2022, 10:42:26 AM
rlgrantjr
I bought a set of DG heads a while back and want to use them.  Both domes have piston and ring shrapnel damage.  I read a post some time ago about SCR saving a set of heads like this.  Does he still do this type of work?
That would be me...
Before:
[/url]
After:
I had this done in 2008, I don't know if SCR is still doing this, reach out to them.
These heads were re-domed for my 350.  My only mistake was not getting the ORing option..
After they came back I also got the heads and the swinger reannodized and chromed the head bolts:
Before:
After:
It is my understanding that Scott retired and closed his shop.
rlgrantjr
Scott is still doing some work, under the radar.  Give him a call (760) 365-4505.
Quote from: Hawaii-Mike on October 02, 2022, 05:10:36 PM
Good to know. :thumbs: I haven't talked to him in a long time but I have some items that need his expertise.
so-cal-sdr200
Thanks for Scott's #.  I need to ask him about the O-Ring size / brand he
uses on his RD250, o-ring head modification.
I am assuming it is a McMaster-Carr part.
Thanks, Jeff
sav0r
You'll have to buy a 10 pack for $6.25 and shipping is $13.50. I love McMaster but for small orders it's tough.
Once you get the size check out theoringstore.com, sometimes it's a little cheaper.
good time to stock up on stainless m6 nylocks  :bacon:
Quote from: sav0r on October 03, 2022, 04:13:07 PM
Here we can take advantage of Will Call for McMaster orders. Just ride over and pick up, no shipping. Same with Sudco :thumbs:
DesmoDrew
Quote from: so-cal-sdr200 on October 03, 2022, 11:11:20 AM
Thanks, Jeff
Should be '039' o-ring. That is pretty much a universal number for that part/size. Same size as OEM Yamaha TZ230/350 o-rings.
so-cal-sdr200
#11
Is this the McMaster O-ring you are referring to?
https://www.mcmaster.com/o-rings/dash-number~039/
Part number 9452K127
https://www.mcmaster.com/9452K127/
Looks like I'll need to order 100 qty.
Says max temp range 250F ?
(edit:)  Looking closer is see 8 other types of rubber with varying temperature ranges in that size.
Thanks, but I dont know stock TZ O-ring sizes.
Jeff
DesmoDrew:
DesmoDrew
rlgrantjr
Just an FYI, I sent Scott a text rather than calling him as I really didn't want to bother him if he's retired.  I have not heard back.
I'm not sure that Scott texts people. His phone number might be a land line.
