we need a pipe ID thread again. So... post up what you have or know. Make sure its accurate. :patriot:
Torque Engineering pipes. Rare, loud, heavy, good on stock porting.
Can run centerstand.
(https://postimg.cc/xN2VrHn0)
1984 RZ350 Factory Pipe Products. Bolt on. Retain Centerstand. Excellent power throughout the range.
(https://postimg.cc/7Cb7vshF)
Excellent pipes for stock or mildly ported motor. Good power throughout the range with significant increase in top end. No Centerstand. Centerstand mount lugs ground down. Sidestand relocation may be necessary. (We did on mine, M in SC fabbed).
(https://postimg.cc/WhGWvt5F)
Denco H2 Killers 1inch diameter stingers race only. Depicted with Chinese scooter cans. No Centerstand. No Centerstand lugs. Emphasis on acceleration. Sign off at 8000. Power band similar to street Dencos with a harder hit.
Moto Carrera Millennium GP - stainless steel, for Yamaha RD400F
Product description from Moto Carrera catalog:Moto Carrera Millennium GP pipes
Available for Yamaha R5, RD350, RD400, RD400F, Suzuki T-500.
Unsurpassed powerband width, peak horsepower output & cornering clearance. A no-compromise pipe for the serious rider. Hydroform constructed by one of the world's foremost pipe builders, former GP tuner Tommy Crawford. These beautiful, well-built chambers are the choice of multi-time WSMC champion Clinton Whitehouse, 1998 Formula RD champion Dick Gruhn & other WERA & AHRMA RD winners such as Scott Bentley & Bob Hurst.
Carbon fiber silencers optional.
Equipped with new-generation aluminum silencers made to our specs by industry leader, FMF. The sound level is lower than our competitors by as much as 20db. Unlike our competitors, we'll provide carb jetting guidelines for your application. After decades of tuning nearly every combination imaginable, we have the baseline tuning specs for your setup.
Fitment notes from MotoCarrera.com -No modifications required to your frame and sidestand can be retained on all RD350 & RD400 models.
-RZ350 sidestand and centerstand can be retained for convenience.
Part numbers:
RD350 #855-301
RD400 #855-401
RD400F #855-405
RZ350 #855-355
RD350LC #855-309
For side-exit option see image here: http://www.2strokeworld.net/forum/index.php?topic=177.msg3372#msg3372 (http://www.2strokeworld.net/forum/index.php?topic=177.msg3372#msg3372)
JL Street Retros, emphasis on Street. Sound cool, allow center stand, look weird, broad spread of power, lighter than stock... barely.
The black pipes are J&R pipes with RD350 headers that allow a center stand. Power comes on at 6k-8.5k but are fairly flat before that. Pretty heavy, look old school are easy to re-pack and apparently came with tapered propriety headers that are near impossible to find..
(http://s148.photobucket.com/user/triplepix/media/2008_062208Gap0141.jpg.html)
Marketed at the time as PHR made for Ron Reichert at Purple Haze Racing by Spec II. Good street pipe. No Centerstand. Bolt on. An excellent street pipe with good performance throughout the range.
Spec II classics, good usable power throughout the entire rev range. Obnoxiously loud especially at higher revs. Nice classic look and good fitment. Centerstand tabs need to be removed or bent over.
(http://s148.photobucket.com/user/triplepix/media/waybetter-1.jpg.html)
No Centerstand. Bolt on. Reduced bottom end. More of a road race pipe. Will rev past 9500 with an undisciplined throttle hand resulting in motor carnage on a Triple.. That being said, still a very good expansion chamber.
Spec II F1, very similar to the classics but the power continues a little higher in the rev range and comes on a little stronger in the midrange. Obnoxiously loud but have a very nice crackle at idle. The version in the pic is the road race version, meaning they are just tucked up a little higher than the street version. Center stand tabs must be removed for these.
DG - no centerstand but tabs can be left alone. These are a low budget pipe, Fitment and build quality is lacking compared to the higher end pipes. A noticeable power increase over stock but lacking in the delivery department compared to the higher end pipes.
Video of Spec II classics on a RD400. They had been repacked at this point as there wasn't much packing material in them.
https://youtu.be/TUTLYBomt6g
Martin77 pipes on my TDR250. Made in England.
(https://ibb.co/wL4FT8H)
K2Tec pipes on my KH400. Made in Japan.
(https://ibb.co/h20Zzx)
Fukui Racing pipes https://www.samurider.com/ (https://www.samurider.com/)
Made in Japan
RD400 version shown. Retains center stand and OEM footpegs
Factory Pipe Products (FPP) with original silencers.
Torque Engineering pipes. Rare, loud, heavy, good on stock porting. Later version w/different tips
Can run center stand.
Jim Lomas Pipes. No center-stand. Decent mid range with a hard top end hit at about 6500rpm. Pulls to 10K. Fairly loud with included silencers. Great quality pipe but you pay for it.
Moto Carrera Millennium SportThese were predecessors to the Millennium GP pipes
(Description from motocarrera.com Mar 2000)Moto Carrera Millennium Sport Pipes $289 set. A replica of the famous Toomey & Factory Pipe Product pipes. Good low end & broad mid-range power with lots of top-end making them an excellent pipe for street or race. Latest technology, FMF Power Core oval aluminum silencers feature stainless steel turn-down tips & deliver strong, broad power with a sensible sound level. The best pipe on the market has been made even better. Compare! Available for R5, RD250, RD350, RD400, RD400F.
Moto Carrera Millennium GP - side exitSee http://www.2strokeworld.net/forum/index.php?topic=177.msg956#msg956 (http://www.2strokeworld.net/forum/index.php?topic=177.msg956#msg956) for details about Millennium GP pipes
TNT pipes on a 1975 Kawasaki H2
Pipeline Expansion Chambers: Very easy to install, excellent fit, removable baffles, light weight and LOUD.
Pipelynes are some of the best old school pipes. Made in San Jose CA
Jim Lomas on an H2.
Are the J&Rs pretty much on par with DGs? Power wise
meh, sort of, but dg will prob make more top power compared. I liked my j&rs on stock bikes. best thing about them was the no mods needed to install them, and you can keep center stand. however, with those, you lose a smasll bit of lean angle. they are old school cool though. not a bad deal for them.
they do sound good.
Small can Gibson/Allspeed pipes;
(https://flic.kr/p/2hC7XSo)20180217_132058 (https://flic.kr/p/2hC7XSo) by dusty miller (https://www.flickr.com/photos/167361504@N05/), on Flickr
Dusty ;D
Large can Gibson/Allspeed pipes;
(https://flic.kr/p/2hJSFpv)25-2-12 012 (https://flic.kr/p/2hJSFpv) by dusty miller (https://www.flickr.com/photos/167361504@N05/), on Flickr
Dusty ;D
Stan Stephens/Lomas pipes;
(https://flic.kr/p/2hJVi3t)3-6-13 008 (https://flic.kr/p/2hJVi3t) by dusty miller (https://www.flickr.com/photos/167361504@N05/), on Flickr
Dusty ;D
what I think would be nice is a small vid to hear the differences in the pipes!
just saying...
All those bikes have been and gone unfortunately. I do have some vids of different pipes but all I would say is the sound on the vid isn't the same as in "real life". My latest pipes sound so much better in the flesh than this vid sounds;
(https://flic.kr/p/2hHkdDy)20191109_134347 (https://flic.kr/p/2hHkdDy) by dusty miller (https://www.flickr.com/photos/167361504@N05/), on Flickr
Dusty
they sound great to me. Thanks
Also found a vid of the small can Allspeeds;
(https://flic.kr/p/2hJW8vF)20171005_142919 (https://flic.kr/p/2hJW8vF) by dusty miller (https://www.flickr.com/photos/167361504@N05/), on Flickr
That is a bit more accurate, sound wise.
Dusty ;D
Anybody ran vanguard pipes can give a review?
Quote from: dusty350 on November 12, 2019, 03:03:04 PM
Dusty
Are those Mutts/Alonze pipes on the orange hybrid?
Hi Jim
No, they are stainless TSA's with Mutt's alloy 6" cans.
I have got a vid somewhere of a hybrid I built with Alonze pipes on. I will try and find it and post it up.
Regards
Dusty ;D
Found it. Alonze (2t Cats) stainless pipes with Mutt's 6" alloy cans;
(https://flic.kr/p/2hL9g7z)20190320_150841 (https://flic.kr/p/2hL9g7z) by dusty miller (https://www.flickr.com/photos/167361504@N05/), on Flickr
Dusty ;D
Basani ---
OK experts, how 'bout these lovelies? Seen at the 2020 One Moto show in Portland.
:help:,Wade
And these:
Gorgeous.
Wade
Quote from: 85RZwade on February 09, 2020, 09:44:30 PM
And these:
Gorgeous.
Wade
I believe those are JL Street Retros.
https://www.jl-exhausts.com/yamaha-r5--rd350--rd400-street-retro-stainless-steel-exhausts-1744-p.asp
Quote from: 85RZwade on February 09, 2020, 09:40:42 PM
:help:,Wade
Got a pic of the rest of the bike?
Yup.
Know the owner?
Wade
Quote from: 85RZwade on February 09, 2020, 10:53:50 PM
Yup.
Know the owner?
Wade
Not personally, but he's @nojoke2stroke on Instagram
Exhaust is made by Jemco in Houston, Texas.
he was a member here before the crash as well. had a full build thread
Quote from: pdxjim on February 09, 2020, 09:57:11 PM
And these:
Gorgeous.
Wade
That's exactly what those are, I have a pair.
I have a pair that I would sell, unless that's what Jspooner was implying.
Quote from: Czakky on February 10, 2020, 03:27:04 PM
Nope, not implying that. I know there are people looking for them tho. Put them in the for sale section, I'm sure they will sell.
Nice looking pipes by Roger Allen at Wicked Motorsports
Fatties! I sure like the natural steel look.
Interesting take on an expansion chamber. No idea if it actually works though
If nothing else, it's an admirable welding exercise
That swingarm and wheel (and tire) are very heavy but they and pipes look cool.
Spotted these on eBay and if I hadn't just bought a set of pipes, I'd grab 'em. Offered for RZ350. What are they, anyone?
Now I only want to hear positive things... I made an offer. I'm a weak, weak man.
Carrera's maybe.
Well. They're RG250 pipes ???
These Spec II for RD?
^^^^^looks like it^^^^^^
Look darn close to my old Spec II...
Cool! Thanks for the info. :)
YES
Hard to see but my buddy wanted some help IDing those chambers. I know they are far away but there are some experts on this forum... He will be sending me more pictures when he can climb over the piles of stuff to snap better pics.
*update* got a better pic and found SPEC II sticker on them. Not sure what they are for though.
Arrow pipes. Probably the smallest pipes made for an RD
I've never seen them. How are they, power wise?
Quote from: Czakky on October 29, 2020, 09:22:59 PM
Not mine, just a pic I found. Only place I have seen them mentioned is Australia
I'm not saying the aren't Arrow pipes, but I am saying I have a stack of Arrow stickers in my collection.
The TDR I rented in Greece in '98 had arrow silencers on it, and they looked nothing like that.
https://www.arrow.it/en/assembled/681/Yamaha-TZR-50-2004
Are RZ350 FPP, Toomey and DG pipes all the same thing?
I have a set of Toomeys and a set of DGs, each for the RZ350, and there are some design similarities bu they are not the same. Can't comment on the FPPs other than what I' seen in pictures, but they appear similar to the other two...with differences.
Quote from: 85RZwade on January 07, 2021, 03:54:01 PM
I know the silencers, hangers and flanges are different, but i have seen it mentioned a few times now that they are the same. They certainly look the same in pics.
FPP and DG
I believe DG and Factory both copied Stuart Toomey's design and dimensions.
These were sold in Canada as Greg Wolf pipes. I wonder if they were just re branded FPP's.
I have never seen any other pipes with the hokey rings to hold the silencers on.
thats def an FPP
I agree.
FPPs on the RD400. They were originally for an RD250/DS7
Looks a lot like yours. I would highly recommend.
Quote from: Barto on April 25, 2021, 12:13:37 PM
Ok, I have failed to recognize these here. FPP? They are supposed to be off of a 400F Daytona. Scraped Bondo on the underside of the right side.
Anybody know what they are? Would they be good street pipes for my otherwise stock, 5500 mile survivor?
Price seems ok at $300. Thanks in advance!
These were discussed a few days ago in a thread in the Ebay section here.
http://www.2strokeworld.net/forum/index.php?topic=3189.0
2steve: Thanks for the input, I got them.
SoCal250: Thanks for the heads up on the other thread, I usually check all my unread posts so I thought I was covered! :huh:
Coffman Pipes
Didn't see any pixs of these, figured I would post. Delete if need be.
J&R power pipes.
what a great looking 350.
Anyone know the brand for these pipes? I ended up getting a basket case '85 RZ350 that I'm gonna put together soon and perhaps start a resto thread. Thanks! :help:
DG: 96.47% sure.
Quote from: 85RZwade on December 11, 2023, 03:57:37 PMDG: 96.47% sure.
It doesn't say anything DG on it. Do the DGs (back in the day) come w/o stampings?
Yup
The newer ones had/have the riveted on badges, but the old ones had no makers marks or logos.
Thanks guys. While we're at it, I got another one .... for a RG500. Tommy Crawfords?
They look like Toomeys to me
I believe these are Pipeline (Pipelyne?) out of San Jose, but I've no way to tell for certain. Anyone?
Had them cerakoted satin black with the can done in red to match paint.
I think Pipeline chambers had aluminum cans. Your set looks like the ends were cut off and replaced with DG type ends.
Dean Moro's Pipelyne chambers were similar to DG, without removable cans.
Those pictured may be modified Pipelynes, but the hangers look different too.
Got any pics of the manifolds or spring hooks?
Quote from: pdxjim on December 19, 2023, 12:57:52 AMDean Moro's Pipelyne chambers were similar to DG, without removable cans.
Took a while to respond but here's the manifolds and header tube. I see you are in Portland. So am I. One Show this year? I'll be showing an RD or 2 there.
Mike
I seem to remember the Pipelynes having wire spring hooks. I sold my set almost 20yrs ago, so ....
No, I probably won't go to the One Show unless I get a free ticket.
My TDR was in the first couple of years Thor did the show. I think 2009 and 2010?
Too much of a fashion show for me now. :whistle:
You can check out my club here: sang-froidridingclub.com
Sign up for the mailing list. We have lots of rad shit coming up this spring.
i have a set of piplynes, they indeed had riveted steel cans. mine had aluminum ones added later but thats exactly whats on that daytona.
Quote from: m in sc on February 19, 2024, 05:20:28 PMi have a set of piplynes, they indeed had riveted steel cans. mine had aluminum ones added later but thats exactly whats on that daytona.
I spoke with Dean and he confirmed these are pipes he built back in 1979. Pretty damn cool. I have 3 sets of pipes for my Daytona - stock, these Pipelynes, and a set of Wicked stainless steel pipes. I might sell the stock and Pipelynes. The Wicked pipes are very good.
Anybody want to guess who made these? They came off a 1975 RD350 and they have been on the bike since the late 70's.
i had a set of coffmans like that. very similar looking to DGs but actually worked. might be dencos as well.
Here's a pic of them on the bike when I got it.
Quote from: rideitfast on March 03, 2024, 12:14:39 PMAnybody want to guess who made these? They came off a 1975 RD350 and they have been on the bike since the late 70's.
I think they are DGs.
