Mystery doohicky
Started by NYSingh, July 21, 2020, 07:52:24 PM
NYSingh
Anyone know what this grey thingy on the bottom of the triple tree is? Thinking it might be a steering damper but haven't seen one like that before.  Funny how years after owning this bike I've never noticed it before.
Moto Guzzi V7III
That's exactly what it is.
NYSingh
That was easy :)  Hmm..so looks like it was stock on RD350s but they ditched it for the RD400? Wonder why. How do these dampers compare with the arm-style ones you see nowadays?
Moto Guzzi V7III
Quote from: NYSingh on July 21, 2020, 09:32:24 PM
That damper moves fairly easily. It is oil filled I do believe. The arm ones are more modern has shocks.
its a paddle in there, with a drilled orifice, that the oil passes through. and yes, its serviceable.
theres a few issues.
1: the rate is? anyone guess. you can play with oil thickness to get it where you want.
2: the 2 tangs on the damper body that go tot the tang on the frame get loose. you can shim this, or as i once did, drill and tap a setscrew.
do they work? yes. is a linear adjustable one better? yes.
not sure why the 400s didn't use them. maybe the longer swingarm ?
they are serviceable. you can split them, clean, and refill. thats what the 2 screws at the top are for. ;)
RDryan
Ha,ha. Good question I asked myself then forgot about. It's on the RD250 as well. Not that it needs it.  :whistle:
