Hello again,
I am going to install the Vitos crank since my crank sustained a lot damage...including the lead weights and such.
My question is I see that the bearings have orings around them. Do I also include green Loctite on the cases when I install the crank? Will the Loctite destroy the orings?
thx
No loctite needed, the o-rings will do the job.
Agreed ^^
However, the o-rings will be looser than when you started if a rebuild occurs. If the crank is OK and you plan to slap it back in the motor, a drop of loctite may not be a bad idea.
Quote from: Striker1423 on June 03, 2021, 10:20:28 AM
Agreed ^^
Or just buy new orings
I guess I wasn't clear in my original post. Sorry about that guys. The original OEM crank sustained a lot of damage. I will be rebuilding with the Vito's crank.
The crank bearings do not have the locating pins as well? So the O-rings and a drop of Loctite will do the job?
thx
Quote from: gargantua350 on June 04, 2021, 09:11:13 AM
thx
You won't need the loctite with it being new. Just make sure the races are clean. Oil free. Otherwise the outer races may start to move.
