Deals Gap 2024: Safety 3rd!
27 Cycles RD 350 - Finally finished!!
Started by 27 Cycles, February 02, 2020, 04:26:15 PM
An outstanding build!  Even if that great looking seat would kill my fat old a$$ in less than half an hour.......
27 Cycles
#47
The seat will get one more thin, soft layer of foam then a cover.  But..  I figure I'm good for an hour.   ;D ;D
If you have been racing bicycles or mountain/downhill bikes (which I think you may have), then your posterior should be more than able to cope  :whistle:
27 Cycles
Front fender is mounted and finished.  When I get and install the ignition, the bike will be able to ride/test.
looks great. is it just one bolt on each side?  :umm:
27 Cycles
#51
Yes, I was a little worried too and was going to make a second bolt somehow/where..  the fender is actually quite thick and so are the mounts.  It's strong as hell and I don't see an issue.  It's actually a Harley fender and no matter how thick you think it is...  it's thicker..😁. You would hate it😀
A steel front fender? From H-D? That must be the latest in "wheelie control"  8)
27 Cycles
My plan is to ride the bike for quite a while before paint, if any problems should arise and I'm sure they will, I will be able to fix/change!  If there was another mounting area for the fender I would certainly use it, there just isn't anywhere for another tab without tapping into the fork bottoms and I just really don't want to do that unless totally necessary, so for now I feel comfortable with how it is.
EE
A year or two ago landspeed racing, a guy put a front fender on his bike (a harley) and secured it but only in a couple spots, as you speed up the tires "grow" they get taller from the centrifugal force, the tire caught the fender, pulled it around under the tire, the tire became a skate and it threw him down at speed. If your racing at least  take a little extra time to design your mounting points. food for thought.. Ed
350GUY
Quote from: EE on March 23, 2020, 02:30:08 PM
Wow, that's scary!
27 Cycles
#56
Work is basically done.  Needs paint and ignition to run, hopefully both happening this month!   I built a center stand and a few other small detail parts to really finish it up.
Very nice, has a from the future look.
Quote from: RDFL on April 01, 2020, 09:41:31 PM
Almost looks like it's out of Mad Max
I like it! Doesn't need paint, looks good raw! :metal:
