Coat inside of tank
Started by rd400greenhorn, March 11, 2019, 01:45:04 PM
rd400greenhorn
Hi guys
So my old fuel tank on the Rd400c has been glasblasted and is completely clean inside out.
Do i coat the inside With some sort of tank coater, and if so, do you recommend any?
Brad-Man
#1
If it leaks, as far as I'm concerned Caswell's is the only one.
1974 RD350
1975 RD350/400 project
1985 BMW K100RS
He ^ means Caswell Fuel Tank Coating.
I second it.  Caswell is good stuff.
Hardy
I prefer to use "redcote" as if someonthing happens and you need to get it out, you can. I don't believe this is the case with Caswell.
I coated my Bridgestone 350 tank with redcote as one day I'd like to remove it to have the tank re-chromed and a few small dents removed.
Thoughts from others?
Tuck
When I restomoded the Daytona, I took the tank down to a reputable radiator shop which also specializes in gas tanks. They were recommended by Arlen Ness, apparently they do all his tanks. They hot tanked, pressure tested, then coated with POR-15. Its going on 2 years now and the inside of the tank still looks new.  :twocents:
Gil Gallad
i've used por 15 a few times now and it's really good. the oldest was 3 years ago and it's still not leaking. buy the whole kit though  8)
cheers, gil.
