Does one exist?
Does the Lowbrow Customs XS650 one fit the RD forks?
What are my options?
Following. Thanks.
Here's where I got mine.
http://rswracing.com/
Quote from: pdxjim on April 15, 2019, 06:09:23 PM
Does one exist?
Got mine here:
Google says "permanently closed" but who knows? Website still active.
http://www.rswracing.com/rd350.htm
+1 (408) 840-1804
*edit: looks like he relocated to Oregon. How convenient for you Jim!
I run the RSW.
It's a one piece brace so be sure to shim it to keep the fork sliders from binding.
Shim stock/slices of beer can work well.
Go ahead and just order one, I have a few customers bikes I put them on. Nice stuff...
Mine bolted right up. No shins and no binding. Love it.
Just for reference, here's an inexpensive brace for the R5/DS7... I ran this until I installed a dampener. It polishes nice and only cost a few bucks....
https://www.ebay.com/itm/NOS-Fork-brace-for-Yamaha-R5-350-motorcycle/223468539045?hash=item3407c34ca5:g:tzQAAOSwKO5bxmn6 (https://www.ebay.com/itm/NOS-Fork-brace-for-Yamaha-R5-350-motorcycle/223468539045?hash=item3407c34ca5:g:tzQAAOSwKO5bxmn6)
(http://s665.photobucket.com/user/edwinalsberg/media/A26833C5-3BA4-4235-90BE-523CAB783885_zpslonbr5vh.jpeg.html)
Later, I switched to this dampener from Economy...
(https://s665.photobucket.com/user/edwinalsberg/media/IMG_0647_zpsjuhandqe.jpg.html)
Quote from: Seizer on April 15, 2019, 09:43:04 PM
+1
Higher quality braces are typically 3 piece, where the center piece bolts on with slotted holes to the fork slider brackets so the sliders ride naturally where they travel.
I've installed two of these. There was a small gap at the fork seal dust cap area where the inner side of the brace meets it.
When the brace was tightened the forks would bind pulling the legs in until the brace was loosened.
Others running this brace have had this issue as well, fixing it with some shim.
I'm not saying you're wrong at all, I'm saying maybe yours was made on a Monday and mine was made on a Friday...
FFP have Tarozzi, but they never made one for the RD350. However, FFP have a list over dimensions, and some should be possible to adapt to an RD350, using spacer rings.
List is downloadable as a PDF at the bottom of this page: http://www.fastfromthepast.com/fork-braces
Quote from: retaRD on April 16, 2019, 01:33:18 AM
Umm...
Mine IS a 3 piece...
Looking at the link, the brace in the pic is a 3 piece design also 🤔
Double post.
Quote from: Seizer on April 16, 2019, 09:12:45 AM
Umm...
Ok, yes, technically RSW is 3 pieces... but it's 1 solid piece BETWEEN the legs, non-adjustable.
When I say "3 piece" I'm referring to the Tarozzi type braces, 3 main functional pieces. .
My point is RSW is not adjustable, and should be shimmed
IF NEEDED to prevent stiction/seizure and excessive bushing and seal wear.
Maybe you got a correct fitting one. I know myself and others have had to shim it to function properly.
Quote from: AAAltered on April 15, 2019, 11:05:56 PM
those were invented in the 70s for bikes with longer, choppered out forks to reduce twisting. a true brace ties the sliders together, just fyi.
I like the retro-style.
Would look good on a street tracker.
