Question on RD400 Pistons
Started by KANDY, October 06, 2020, 11:03:28 PM
KANDY
Hi All,
Quick Question to confirm. Can I use RD350 Piston on 1977 RD400
Thanks
1974 RD350
1977 RD400
1979 RD400 Daytona Special
Yamaha 179
Yes you can.  You might want to think about it a bit, i.e., you should match brands and types as much as possible to minimize possible problems (except in an emergency) but they will work.
Lyn Garland
KANDY
Thanks Lyn, Got a deal on RD350 Wiesco second Oversize.
It does not have the cut on the exhaust side, does that make any issue.
1974 RD350
1977 RD400
Yamaha 179
None at all; in fact that is better.  You know forged pistons require more (looser) clearance, right?
Lyn
KANDY
Yes, I will maintain the specs needed for Wiesco.
Thanks again Lyn
1974 RD350
1977 RD400
I'm confused...Aren't RD350 pistons smaller than the RD400 cylinder bore?  :umm:
Quote from: quocle603 on October 07, 2020, 02:26:48 PM
Both are 64mm bore
Diablo007
Longer stroke on the RD400.  RD350, RD400, and RZ350 pistons are basically the same; though the tang' on the RZ350 piston needs to be removed before using in an RD.
http://www.greasygringo.com/2012/03/using-banshee-pistons-in-your-air-cooled-rd350400/
Can the RD pistons be used in an RZ350?  Never thought about that as RD pistons seem to be the ones that are hard to source nowadays.
2 stroke junkie:
Quote from: SoCal250 on October 07, 2020, 02:28:56 PM
Both are 64mm bore
It's the stroke that makes up the extra 25cc's in each.
Quote from: Diablo007 on October 07, 2020, 02:36:08 PM
Rd windows are smaller than the RZ / Banshee pistons, so it would be a downgrade
Diablo007
@rodneya
Thanks for the info.  Seems I oversimplified things in my mind.  There are differences in design beyond the 'tang'.
2 stroke junkie:
Thanks for clearing things up for me. I did not know that! I've always thought that the bore was overall bigger.
I've done this. Works great with my build...
