Powerdynomo CDI upgrades and install (Vape)
Started by SUPERTUNE, August 11, 2019, 09:07:48 AM
motulman
Quote from: SUPERTUNE on July 09, 2020, 09:52:46 AM
Quote from: motulman on July 07, 2020, 08:00:39 PM
hey chuck its been a long time,  does this installation cover the daytona also?
Pretty much the same as RD400's, the difference with a Daytona model is the headlight signal relay yellow wire from the stock stator.
I don't remember what I did exactly...I think I just may have jumped the relay in the headlight shell to turn on with the key and not use the relay.
i wish you would remember what you did exactly
just bypass the relay, run switched power directly to the headlight switch.
motulman
mark there is no headlight switch on a daytona
theres a hi/lo switch correct? power to that can be fed from switched 12v
when key is on, HL is on. since the ign doesnt need power to fire, persay, no peril.
motulman
ill look into that mark  thank you, just dont want to burn it up
toffee
What a great thread packed with great info!
Brilliant, Thanks Chuck.
I am currently in the process of fitting a Powerdynamo system on my 250b
The relay is relay is really confusing me [that isnt hard to do  :eek:]
ATM I have just fitted the unit and wired up everything as per the instructions
supplied with the system.
I probably should make sure that the pin connections match what is posted here.
There is a clack wire from the relay with no connection fitted but I have no idea
where that connects to.
Im using a U.S loom
