Neat little oddball bike, zero info.
Whats in my garage
Started by busa1300, March 24, 2019, 06:11:25 PM
busa1300
Thanks guys  :thumbs:
Still have a long way to go.
Fork's showed up today, (after 9 weeks) so I did a dry build on them with some rebound spacers to drop it a little. Still want the front a little lower, but with some weight on it, it should level out when completely done.
Will hopefully get some emulators ordered next week sometime, then I can put the front end on for good.
RZ350-RZV500R-TZR250RSP 3XV2
busa1300
:cheers:
I got my tapered head bearings installed. Emulators came this week also, and then made some measurements from them and my lowering spacer. Cut my springs today to get the right preload, and did another dry build of them to see if my calculations got the bike to level out like I wanted.
Looks like what I had in mind, so apart the fork go again and then add the piston ring, oil seals, dust caps, and oil...then I'll be done with the front for good....I hope
Time to turn some attention...and $$$ to the motor rebuild now.
Wow, that's looking fantastic! :clap:
1972 Kawasaki H2 750 Mach IV
busa1300
 :cheers:
Thanks guys.
It is going on one year since I brought this bike home....and still no where close to being done. Think my days of rebuilding are starting to come to a close.
busa1300
A quick vid of slow progress
Will finally get the crank and cylinder sent out within the next week so I can start on the engine soon.
